1970 Suzuki T250-II Oil Line Check Vavle Question
Posted: Sat Feb 12, 2022 3:21 am
I have cleaned and checked over the oil lines on my 1970 Suzuki T250-II and I have tested both lines which have provided the following pressure readings. The right hand side oil line top check valve opens at 5.5 psi and the bottom check valve opens at 4.5 psi. The left hand side oil line top check valve opens at 5 psi and the bottom check valve opens at 5.5 psi.
Because of the readings are different, you need to provide at least 6 to 6.5psi to both sets of oil lines for all the check valves on each oil line to start to leak oil. Under normal running conditions, will the oil pump provide 6 to 6.5 psi or will the oil pump only provide enough pressure to open the check valves that start to leak oil at the lower pressure of between 5 to 5.5 psi which means 1-2 of the other check valves will not open?
Also, does anyone know if you can get a set of replacement check valve springs for the early model Suzuki check valves which can be disassembled
