1969 T350 - Clutch Spring Free Length
jsjays1
Suzuki 2-Strokes: 1969 T350
Post by jsjays1 »
Hello All,
This is my first post on the forum, but I've been reading and learning for the past couple of months as I try to get a 1969 T350 back on the road.
One of the last remaining issues I have is that I have not been able to get the clutch mechanism adjusted properly yet. Running on the center stand, when the bike is in gear the clutch drags, even when the lever is fully pulled. I've tried adjusting the cable, and adjusting the screw under the clutch cover, but I'm still not having any luck. So I started to disassemble today, thinking that I may have an issue with burrs on the discs/basket causing everything to get hung up.
As part of that troubleshooting I found an interesting discrepancy in how my bike is setup versus the Haynes manual that I have for the bike. The free length of the springs that were installed into the bike is around 1.47", but the Haynes manual states that they should be 1.87", with a serviceable limit of 1.79". Can anyone confirm that the Haynes manual notes on spring length are correct? I think the Suzuki P/N is 09440-19004 if that helps.
Thanks for any help or advice that you guys can offer!
- James
jsjays1
Re: 1969 T350 - Clutch Spring Free Length
Post by jsjays1 »
Ordered new clutch springs - P/N 09440-19004, and they were nearly the same as the old ones in the bike, about 1.50" length. So the Haynes repair manual value was wrong.
Sanded a few rough areas smooth on clutch basket and took he bike out for a ride and the clutch is working great now. After riding for about 30 seconds or so around the neighborhood to warm up the clutch drag is minimal.
markush
Country: Germany
Suzuki 2-Strokes: GT250/380
Post by markush »
Hi.
Saw your November post only now...
Your spring part number is from T305/350, GT380/250A...
Free spring length new is 38.5 mm, service limit 37 mm. see eg. GT380 Service Manual or in the Bulletins.
Haynes is a little wrong sometimes :roll:
jsjays1
Post by jsjays1 »
No worries, thanks for the information! It's good to know the part is interchangeable with a few other models if I ever need to find it again too.
