Wet sumped my T125
Posted: Wed Sep 09, 2020 3:10 am
by F5
Hiya long time. So my T125 was restored in a fury of activity when I found myself with some time. To about 90%, needs paint finish wiring etc,
Had full crank rebuild etc. Then got busy with other stuff so just put it to the side until rush cleared.
After 3 years I noticed it was dripping injector oil from ex ports (rags stuffed in there) I think. Anyhoo, at year 4, (last weekend) I got some pipes, changed the ignition points and have sparks. But what about the emptying oil reservoir?.
I pulled out the crankcase drains (jolly convenient). The left dropped out a mug of 2 red stroke oil. The right one was dry.
So I guess it I'd coming from the pump and into either the left bearing or maybe the centre.
What to do now?
Re: Wet sumped my T125
Posted: Wed Sep 09, 2020 5:35 am
The oil lines have check valves that should stop the tank draining when the pump is not working. One of those valves is likely stuck open.
Flush out the lines until you get good flow from each line & the valves close to stop the leaking. Do NOT use compressed air because it will ruin the valve springs.
Posted: Wed Sep 09, 2020 12:58 pm
by F5
Thanks I did wonder about them and got a spare set of manky lines out last night to blow through but was inconclusive.
Do I take the lines off and try clean them out? Maybe with kerosene? Some syringe action, but banjo bolts make that difficult.
Posted: Wed Sep 09, 2020 1:20 pm
by F5
Ok, maybe take them off, fill a spare tank with kero, and hang them over a bucket?
Posted: Thu Sep 10, 2020 3:46 am
by dollydog
i'll try and explain this as best i can. if you've got a squirty type oil can with a pointed nozzle on it, makes it far easier. put a banjo bolt through the feed banjo and leave the nylon washers on. get an m6 nut and screw it on the banjo bolt - just hand tight will do. push the oilcan nozzle as tight up to the banjo bolt inlet as you can and squirt oil through the line. it should come out the twin ends every time you pump. if it doesn't come out you'll know one or both non return valves stuck and kaput. if they are ok, then hang the oil line up with the 2 banjos hanging down - over an old tub will do. if it keeps dripping you'll know the nrv's aren't seating properly. either problem, then don't use them. it's easier to do than to explain
Posted: Thu Sep 10, 2020 4:54 am
dollydog wrote:i'll try and explain this as best i can. if you've got a squirty type oil can with a pointed nozzle on it, makes it far easier. put a banjo bolt through the feed banjo and leave the nylon washers on. get an m6 nut and screw it on the banjo bolt - just hand tight will do. push the oilcan nozzle as tight up to the banjo bolt inlet as you can and squirt oil through the line. it should come out the twin ends every time you pump. if it doesn't come out you'll know one or both non return valves stuck and kaput. if they are ok, then hang the oil line up with the 2 banjos hanging down - over an old tub will do. if it keeps dripping you'll know the nrv's aren't seating properly. either problem, then don't use them. it's easier to do than to explain
I use a banjo bolt & a short piece of fuel line. Pressing the nozzle against the fuel line works a bit better.
Posted: Thu Sep 10, 2020 12:30 pm
by dollydog
thing is jab, i've got a pump action [squirty] can with a very pointed nozzle on it, and it fits inside the open end of the banjo bolt. it's a rigid type can, not one of those springy ones that wiggle about all over the place
Posted: Thu Sep 10, 2020 12:58 pm
by F5
I
do have a squirty oil can with a pointy nozzle on it. Well a steel tube. That sounds like a grand idea, thank you.
It actually has 2 stroke oil in it presently, but I could change it to injector type oil to be sure.
Right. A plan.
