Gt550 exhaust gaskets
- Country: United States
- Suzuki 2-Strokes: 1974 GT550
I'm getting ready to put my stock exhaust back on my 74 GT550. The question I have is is there a certain amount of header pipe that should be sticking in the head beyond the threaded exhaust clamp at the ports as to crush the gasket? I have looked and can't find any info on this. Thanks in advance!
- Country: WALES
Re: Gt550 exhaust gaskets
Hi. Just make sure there are no old gaskets in the cylinder then just put a new one in. Unwind the clamp so that when the exhaust is tightened down a 2mm gap is left to allow the downpipe to flex when the motor is running. The reason I say to check the old gasket has been removed is because when compressed and with heat and carbon they are very good at disguising themselves
98 carb Blackbird and GT550j
Awesome! Thank you! I did remove the old gaskets and cleaned all the exhaust ports. It no longer looks like the inside of a BBQ grill.
Also what is the torque spec for the exhaust flange bolts?
- Country: WALES
As far as I am aware there is no torque setting for these bolts. Just apply some copper grease and do them up tight a little at a time swapping sides so the clamp pulls in square. Don't over tighten just as tight as you dare.
After running the bike for a while, just go back and check they are still tight.
Easy enough. Thanks again.
