Pressed in SRIS valves
motorpsycho
Suzuki 2-Strokes: Suzuki GT550, Kawasaki ZRX1200,YamahaR5,
Post by motorpsycho »
Anyone ever remove one and SUCCESSFULLY get it back in?
Looks like it shouldn't be too difficult.
GTandcbr
Country: WALES
Re: Pressed in SRIS valves
Post by GTandcbr »
They are a tapered end interference fit. If you use a socket and rock it back and forwards but dont press forward it will come out. :D
98 carb Blackbird and GT550j
motorpsycho
I've already removed it, was concerned about getting it back in...….
Pop it in the fridge and it will tap in easily. I made a little pusher that goes over the spigot to protect it. Just a bit of steel with a hole drilled in. The spigot goes in the hole and you tap t'other end. I also put a thin O ring on the part that goes in the cases, and a smear of loctite to hold it in position.
http://www.kettleclinic.co.uk/kcforum/v ... &start=120" onclick="window.open(this.href);return false; towards the bottom of the next last page.
