GT750 Steering Stem Mod
- yamahale
- Suzuki 2-Strokes: GT750
Hi, I know about the mod needed to accept tapered roller bearings, I have the smaller dimensioned one and want to convert. For various reasons I cannot dry fit at this time so I dont even know if it needs it. We have a lathe and a coworker who can run it, but he says the stem has to be pressed out so it can be chucked up. I really dont want to go to those lengths, do most folks just carefully grind them? Thanks
Re: GT750 Steering Stem Mod
If your lathe is too small then you can just grind them, or most people use a file. On a larger lathe it is an easy job and the entire steering stem can be run between centres. Use a slower speed and you'll find the balance isn't a problem.yamahale wrote:Hi, I know about the mod needed to accept tapered roller bearings, I have the smaller dimensioned one and want to convert. For various reasons I cannot dry fit at this time so I dont even know if it needs it. We have a lathe and a coworker who can run it, but he says the stem has to be pressed out so it can be chucked up. I really dont want to go to those lengths, do most folks just carefully grind them? Thanks
- yamahale
Thank you!
I've done 3 x GT550s so far and just used emery tape. Wrap it around the stem and use a to and fro pull method and measure regularly. Doesn't cost much either!!
