GT550 clutch cover + points cam question
Posted: Wed Feb 14, 2018 11:49 am
This is for the GT550 cafe build.
I have the clutch cover off and need to disassemble the points cam assembly.
Didn’t find any guidance in the shop manual. What’s the best way to do this?
Re: GT550 clutch cover + points cam question
Posted: Wed Feb 14, 2018 2:23 pm
http://www.alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Look at year = 1975 (M)
Contact Breaker - Nippon Denso (doesn't matter if you have the other, this shows more detail).
Don't lose item 29 - pin!!!
It locates the 'propeller' and points cam.
Posted: Wed Feb 14, 2018 7:26 pm
How do I stop the shaft from turning when I remove the cam nut?
Posted: Thu Feb 15, 2018 3:21 am
Wrap the inner end in a cloth and hold it with pipe grips, or just put the cover back on the engine and line up the cutaway. You won't have to hold it then.
Posted: Thu Feb 15, 2018 5:08 am
Thanks.
The crank is getting rebuilt & I need to get the cover polished + clear coated. So I’ll give the other method a try.
Posted: Thu Feb 15, 2018 9:46 am
Turned out to be easy with a tool that I already had.
Used an adjustable hook spanner, a Proto C472, that looks like this:
Now that I have the cam drive out,
(1) how do I get the tach drive out, &
(2) how do I get the bearings out without ruining them?
Posted: Thu Feb 15, 2018 11:09 am
The tach drive was easy. Just attached the old tach cable and used it to pull the tach drive out.
Any tips on getting the bearings out without ruining them?
