Fuel Tap Diaphragm part number?
Olafskii
Suzuki 2-Strokes: 72 GT750, 74 GT750, 75 T500, 76T500, 09 DR650
Post by Olafskii »
Does anybody know what the Suzuki part number is for the petrol tap diaphragm assembly? The Suzuki parts book doesn't show this diaphragm side of the petrol tap disassembled (so no part number).
Olaf
Re: Fuel Tap Diaphragm part number?
I've never seen one for sale. Just buy a new petcock.
A little shop in Germany sells newly manufactured diaphragms. (Use Google translate for English translation.)
https://hard-to-find-parts.de/epages/af ... hn_Auspuff
Not cheap!!! New MAB exhaust system! Really not cheap!!!!
rngdng wrote:Not cheap!!! New MAB exhaust system! Really not cheap!!!!
I have an original parts manual for my 1969 T350. Was used by a dealership and has the prices penciled in.
From that perspective most parts have gotten really expensive.
But just price out the corresponding parts for a new bike.
Was curious so I just took a look at a dealership website & priced out an exhaust system for a 2013 Honda CB1100.
The 4-into-1 header is $1,773. The muffler is $896.
sportston
Country: England, UK
Post by sportston »
Welcome to world of classic 2-strokes. You either need to be rich or capable of compromise and ingenuity. New genuine parts cost one arm and two legs, whilst aftermarket parts only cost an arm and one leg.
If you are obsessed with originality it will seriously deplete your coffers. If you just want to make your bike usable, but not standard you can save a lot of pennies. If your crankshaft needs rebuilding, its time to start spending the kids inheritance. :lol:
dollydog
Country: england
Post by dollydog »
get a 200mm x 200mm square of 0.3mm thick and make your own - i do :D
https://www.ebay.co.uk/itm/Nitrile-Nylo ... c_j9zWgw3A" onclick="window.open(this.href);return false;
Olafskii
Post by Olafskii »
Thanks DD and jabcb. The German hard-to-find-parts.de was good enough to include a detailed photo of a disassembled diaphragm assembly. Based on this it doen't look too difficult to 'rebuild' my old diaphragm assembly with nitrile sheet. I'll post some photos when I get to it.
Olaf
akendall1966
Country: United Kingdom
Suzuki 2-Strokes: T500_MKIII
Post by akendall1966 »
Unless your particularly interested in retaining the vacuum on/off you can modify the petcock to be off - reserve - on so the diaphragm becomes redundant. This is the route I took retain OEM look but converted to manual operation.
See:
viewtopic.php?f=9&t=12452
I thought I had a post with pictures, if I can find it I ll post a link to that as well.
markush
Country: Germany
Suzuki 2-Strokes: GT250/380
Post by markush »
Olafskii wrote:... Based on this it doen't look too difficult to 'rebuild' my old diaphragm assembly with nitrile sheet...
I did it that way.
http://suzuki-gt250.de/motornavi/motor.php?b=8&m=M1
https://translate.google.de/translate?s ... t=&act=url
dollydog
Country: england
Post by dollydog »
a word of warning though, olaf. always punch the holes out before cutting the outline out. holes are close to the edge and it's very easy to split. then you start again :D when making any gaskets, such as clutch cover etc, i always punch the holes out first, making sure there's plenty of gasket either side of the hole. hollow bore punch set is perfect and sit the gasket on a nice thick piece of hardwood. a good light source over the top of you helps when centreing the punch over the holes.
