Re: GT750 idle issue
Posted: Fri Nov 17, 2017 2:50 pm
Well I believe I've located the problem....Cranks seal on the center cylinder.
Got tired of yelling at the carbs and pulled them off along with the pipes.
Plugged everything up, right cylinder is as it should be. Held 7lbs no problem,
Center cylinder wouldn't even think of coming up on pressure. I had to double check all the plugs as I was sure I had one not sealing....Nope. One of the center crank seals is non functional.
Left cylinder would pressurize but leaks down pretty quickly.
Out she comes.....
At least now I can quit calling the carbs names!!!
The engine didn't have 300 miles on it when I sold the bike.
Crank was rebuilt when the bike was restored: all new components.
Friend put a couple thousand on it before she started acting all wonky.
I've cleaned numerous carbs on bikes for this man and they always come in all sticky and green.
Seems that non ethanol gas with an overly generous helping of Stabil 360 will mess up some stuff in very short order.......
Out she comes.....
