pulsing drum brake
pulsing drum brake
What can be done with pulsing drum brakes?
I used search & found mention of the wet & dry paper trick but I don’t know what that is.
viewtopic.php?f=22&t=10624&p=146887&hil ... um#p146887
Re: pulsing drum brake
The question is whether the pulsing is caused by a rust patch on the drum or if it's out of round.
If it's out of round I guess you could try to stick wet and dry on the shoes and apply the brakes lightly (not on a moving vehicle of course) and see if that skims the tops off the high spots. I would be surprised if it made much difference but may be worth trying.
The real answer is to have the drum skimmed.
