oil seals
Posted: Sun Jan 03, 2016 7:17 pm
by stevebee
can you still buy the kickstart seal , gear shift seal,clutch pushrod seal, countershaft seal for a t500
Re: oil seals
Posted: Sun Jan 03, 2016 7:37 pm
by ConnerVT
All should still be available from Suzuki. Not sure on your side of the planet.
Re: oil seals
Posted: Sun Jan 03, 2016 8:10 pm
by stevebee
thanks
Re: oil seals
Posted: Mon Mar 21, 2016 5:49 pm
by PippiFyrecracker
I ordered the engine oil seal kit from ebay, pretty sure it came with everything.... I also found out after wards that a local bearing and seal company probably could have sold me seals for suuuper cheap
Re: oil seals
Posted: Mon Mar 21, 2016 8:48 pm
by sbaugz
I ordered all those for my bike from bikebandit
Re: oil seals
Posted: Fri Mar 25, 2016 9:43 am
by oldjapanesebikes
As already mentioned - always check with your local dealer first - it is sometimes surprising what can still be ordered. And if that doesn't work, then check with a bearing and seal specialist supplier as you can usually match them up. If both those fail - then check first with Reiner in Germany or Marcel in NL, and then check eBay.
Re: oil seals
Posted: Sun May 08, 2016 8:38 pm
by PippiFyrecracker
PippiFyrecracker wrote:I ordered the engine oil seal kit from ebay, pretty sure it came with everything.... I also found out after wards that a local bearing and seal company probably could have sold me seals for suuuper cheap
correction...so it was a hydraulics company that carried various seal, and also an update on the kit bought from ebay, I used the outer crank seals already and they were good
Re: oil seals
Posted: Mon May 09, 2016 8:53 am
by sbaugz
ordered all mine from bikebandit as well. 10% discount if you are an AMA member on everything at bikebandit. (although I now see that you are in Australia so I doubt you are an AMA member).
Re: oil seals
Posted: Tue May 10, 2016 4:10 am
by parksie
You should be able to get them from Suzi Parts Australia in Adelaide. email:
sales@suziparts.com.au The blokes name is Ray.
If your not successful there send me a PM , I still have quite a few new ones in the shed.
Bob
