Word of warning re: powder coating
Posted: Fri Apr 24, 2015 6:05 pm
Just a little thing to be aware of, I just had my GT500 frame powder coated. (At last I can start the build
I masked off but didn't remove the swing arm fibre bushes.
It looks like the heat of the powder coating curing has slightly shrunk the fibre bushes. They are now a slightly looser fit in the swing arm, and the steel bushes which slide into the fibre bushes are tight in the fibre bushes. (The guy who did the coating said they cure at around 200 degrees C).
Nothing I can't fix with elbow-grease and careful fitting, but just a tip for anyone else doing the job.
