Every small head bolt broke off in my jug. Now, two of them broke off above the jug, 1 broke off below the jug (PO) and the rest broke off at the jug. One of them that broke off above the head I was able to extract by grabbing on with a pair of vice grips and rocking back and forth until it became loose. The second one I tried broke off at the jug. So, it does seem the issue here is corrosion in the threads. I had to use a shim system to get the head off, so the jugs are going to require a puller. My issue there is I cant secure a puller since all the bolts are broken off.
I dont want to use an easy out, because there is a 100% chance it'll break off in one of them then I couldn't even get a machine shop to drill them out.
Black = slightly above the jug, but not enough for vice grips
Blue = Broken at the jug, pretty much flush
Red = Broken below the jug
Green = clear
Anyone have any advice?
