Gt380 transmission shifting issue
Posted: Mon Oct 06, 2014 3:56 pm
Hi folks! I posted a gt380 "stuck in neutral " post a while back and I did get help on getting the shifter unstuck. I believe I put
the Pawl in the right position, by the photo posted from all the kind help I received. The Spring at the end of the shift arm
near the pawl was not in the correct position so I put the spring tabs on each side of the post. I put the cover back on .
Now! Here is my problem... The shifter is real sloppy. By the gear light I can get Neutral , 2nd and 3rd only! and the other
issue is.. I can shift without engaging the clutch. In fact , when I engage the clutch it has no baring on the transmission at all.
When I put the trans in gear, it is in gear and when I shift the trans in neutral , it is in neutral.
I adjusted the clutch twice, thinking this was the problem but apparently not!
I hope you smart guy's out there can help me with this problem... Thanks!!!!
