T500 Drum Brake Service Limit ?
This must be in one of the manuals, but if so then Suzuki have made it really hard to find :cry: - anyone know what the service wear limit on the front and rear drum brakes are for the T500 ? There are no numbers cast inside the drums or the back plates on mine (its an MK1). I ask as the drum is a bit oval and I'm wondering if there is enough material there to allow it to be skimmed or if I have to replace it. The front drum looks to measure about 200.17 +/- .05 mm Thx ! 8)
Fritz500
Re: T500 Drum Brake Service Limit ?
Post by Fritz500 »
The drums on my 72 T500 have the following cast inside the drums:
Front = "MAX. DIA. 200.7 mm"
Rear = "MAX. DIA. 180.7 mm"
Geoff
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
Fritz500 wrote:Front = "MAX. DIA. 200.7 mm", Rear = "MAX. DIA. 180.7 mm"
Perfect - thanks Geoff - appreciated ! :up: Looks like if I decide to have it skimmed that I have at least a bit of material to work with. 8)
Fritz500
Post by Fritz500 »
Glad to assist. I just noticed the GT750 front drum is also 200.7mm.
Geoff
72 T500J - 95%
09 Yam XVS950A
