GT550 charges well when cold but stops charging when hot.
- Suzuki 2-Strokes: 74 GT550, 90 RZ350 (Canadian), 78 DT250
Re: GT550 charges well when cold but stops charging when hot
I know you were.... I never took it otherwise. Thanks.
I must do this check on the rotor on my own triple -- I suspect I have the same problem.
I think I would have solved the problem sooner and spent less money if I hadn't focused on "stator". At one point I convinced myself it was the stator and bought one from Ebay. Because something was nagging me, I didn't install it. I then rechecked the rotor, cold and hot and discovered it was the rotor that was weak to start with, but would charge, and then failed when hot.Craig380 wrote:I must do this check on the rotor on my own triple -- I suspect I have the same problem.
I now have an extra stator and the old rotor is a great paperweight.
