72 J model.Pipes are nice but lacking baffles and cones.My buddy has some baffles from a set of 74 pipes.From my limited research looks like dealer says they are different,but bikebandit appears to think they are the same.Anybody?
I just googled the dealer part # to come up with that info from bikebandit.............
Center 484840-001
mufflers 484835-001
First dumb question
According to my part lookup, baffles are good for all years:
Outers:
Part # = 14510-31000
Part Description = PIPE,MUFFLER BAFFLE
GT750-B 1977 738 GT750 LEMANS STREET
GT750A 1976 738 GT750 LEMANS STREET
GT750J 1972 738 GT750 LEMANS STREET
GT750K 1973 738 GT750 LEMANS STREET
GT750L 1974 738 GT750 LEMANS STREET
GT750M 1975 738 GT750 LEMANS STREET
Inners:
Part # = 14610-31000
Part Description = PIPE,MUFFLER CENTER BAFFLE
Cones for the outer pipes are larger than the inner pipes, therefore different. But you probably knew that:
Larger-
14860-31000
COVER, REAR
Smaller-
14880-31000
COVER, REAR CENTER
If they are missing, don't forget to get the rubber gaskets that are behind the cones, you will need those- very necessary.
14869-31000
CLIP, MUFFLER REAR COVER
14889-31000
CLIP, REAR COVER CENTER
Outers:
Inners:
Larger-
14860-31000
COVER, REAR
Smaller-
14880-31000
COVER, REAR CENTER
14869-31000
14889-31000
There's a guy in Australia that makes perfect repros of the outer cones for US$ 85 plus shipping. He is on fleabay quite regularly. It's not likely you will find them at a dealer, because I think they've been out of production for some time. There is no mention of any inner cones yet form the guy. It's worth the hunt, because the bike just doesn't look right without them.
Cheers. Fred
Cheers. Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
I've already exchanged emails with him.He says the small cones are in the pipeline.Anyone have a pic of the rest of the hardware I need like the rubber gaskets?Still available?Buffalo-guy wrote:There's a guy in Australia that makes perfect repros of the outer cones for US$ 85 plus shipping. He is on fleabay quite regularly. It's not likely you will find them at a dealer, because I think they've been out of production for some time. There is no mention of any inner cones yet form the guy. It's worth the hunt, because the bike just doesn't look right without them.
Cheers. Fred
Here is a good online look-up parts fiche resource, it is complete with all the numbers, not just the ones still available:
http://www.alpha-sports.com/suzuki_parts.htm
They're prices aren't the best, however. ^
If you can find stuff available still, here are two good places to check for parts other than your dealer...
http://www.motorcitypowersports.com/fiche_select.asp
http://phoenixpowersports.com/fiche_select.asp
Here is another good place to explore for info on your bike...
http://www.3cyl.com/~mraxl/gt/index.htm
Need any help, PM me and I will try and lend my limited ability to the problem.
