Hi Guys, I haven't been on here for awhile, I have an on going issue with one very oily baffle/exhaust left cylinder on my GT750A, dripping black oily liquid to the ground, whilst on the side stand, the other 3 are dry, by comparison. I change the gearbox oil awhile ago, & I always measure what comes out, this time it seems a little less, I do have a small oil leak from the points cam seal which I must fix
2 stroke Oil consumption appears normal after marking the tank level and riding 100 miles or so, I thought I may have a leaky check valve on that oil line
I think I'll undo the SRIS valve on the front of the left cylinder tomorrow & see if any accumulated oil/fuel dribbles out of the crankcase,bike is running fine otherwise,bike smokes only when under load up long hills,& when its started from cold. I did think that it may be accumulated condensation, all four pipes do have this to some degree until the bike is ridden up to temperature except the left cylinder of cause. I've been using Castrol TTS 2stroke for years now without problems, while I'm here can someone tell me how to change my password
