t500 engine cases
stevebee
Country: australia
Suzuki 2-Strokes: t500 kawasaki z900 harley davidson flsti
t500 engine cases
Post by stevebee »
Can anyone tell me if I can put crank and gears from a 1971 engine into 1976 cases
ConnerVT
Re: t500 engine cases
Post by ConnerVT »
1971 = T500 with point ignition.
1976 = GT500 with CDI
Crankshafts are different, have a different end on the crank on the ignition/alternator side.
stevebee
Country: australia
Post by stevebee »
ConnerVT wrote:1971 = T500 with point ignition.
Will the 1971 crank fit if I stay with points
Jimroid
Post by Jimroid »
Cranks interchange.You just need to use points ignition with pre-76 crank.
stevebee
Country: australia
Post by stevebee »
Jimroid wrote:Cranks interchange.You just need to use points ignition with pre-76 crank.
You should consider doing the transmission mod. Its in this service bulletin:
http://www.ozebook.com/compendium/techb ... %201-5.pdf
bugspray
Country: canada
Suzuki 2-Strokes: gt 500 x2
Post by bugspray »
Crank and gears will interchange but the stator plate for electronic ignition sits a little further out. You can shim out the
three bosses on the casing to properly locate the electronic (GT) plate.
Buy the way PaulMiller has two cases on Ebay that come from me serials 68567 and 43852 that I consider were not paid for.
He also stole a GT crank from me and does not reply phone or Emails. You will also be seeing 12 mufflers, 8 carburetors, gas tanks, wheels
and a whole pile of other stuff that were not compensated for.
Warren
stevebee
Country: australia
Post by stevebee »
bugspray wrote:Crank and gears will interchange but the stator plate for electronic ignition sits a little further out. You can shim out the
Warren
Thanks for the information . I have never had any dealings with Paul Miller I hope it works out for you
