Pre mix ratio?
Eddie
Suzuki 2-Strokes: 1974 gt750, 1963 superhawk
Pre mix ratio?
Post by Eddie »
Ok, I'm going to run pre mix plus the oil pump, so what's a good ratio if running both? I don't want to be crop dusting everywhere I go, but I'm worried about the one cal not getting oil, so what ratio do you guys run when running both?
Re: Pre mix ratio?
I would normally only ever run some pre-mix (in addition to the injector system) for the first quarter or half tank after an engine rebuild till I'm sure everything is working. So 40:1 seems to work OK - its just for insurance eh ? 8)
