Media Blasting GT750 Cases
- water cooled
Re: Media Blasting GT750 Cases
Hope you didn't do the blasting twice too!
- Country: U.S.
Looks fantastic. I pretty much did the same thing. Turns out looking great. Downside, you 'll have to keep after it ( polish ) quite often to keep it looking that way. The good thing about painting the cases, you only have to take a rag to them every so often. But, paint doesn't look nearly as good in my opinion. And will eventually peel or show it's age. Be sure to post more pics when you have it installed.
- water cooled
Blast once....post twice!
Thanks Pearljam. I'm really happy w the result that John was able to get. I'll post pics of the rebuild. Bike Should be done by end of March.
Purdy ! Just curious - is that hole drilled through the engine case number there for a reason ?
- water cooled
Ian, I was very reluctant to drill that hole through the serial number but thats where the chain guard needed to mount. I figured my motor is modified to such an extent that no one would ever want those cases and I could never see myself selling them.....so that was the spot I picked to mount the front of the chain guard. Great catch by the way. You have an excellent eye!
- Country: U.S.
Racing / chainguard That makes you heavier or does your track organization require it ?
- water cooled
Everyone has to run a chain guard...part of the requirements. Ive been told (by the committee) that mine is slightly under spec. So I opted for a Pingel guard to fit this winter.
Yours is under sized - and you are such a big strapping lad.
What are the rules on chain guards then? I thought they just had to have one without specifying size or length or thickness etc. I'd better check that for next season.
- Country: uk
just curious or being dim..... But! a fixed point for a chain guard?? not on the swing arm, hows that work??
His bike is a dragster Pete - hardtail.Pete O'Dell wrote:just curious or being dim..... But! a fixed point for a chain guard?? not on the swing arm, hows that work??
- Country: uk
clearly being dim then Ian, lol
How is the engine assembly coming along Kevin ?
- Cliff
Probably don't have to say this, but after being blasted, clean with soap and water (pressure wash if possible) and blow dry the cases. Then do it again!! It's amazing where and how much media can be hiding in there!!
I would drill and tap the hole for the water pump removal now too! And don't forget to put the water pump locating bolt in the lower case!! (Been there, done that!!)
In the pics, several of the bolt holes have a black marker dot beside them? Why??
- water cooled
The holes w black marks are the ones that had the threads chased. The glass beads can hangout in there and cause problems. The dots represent the holes that are done so we don't miss one.
