Hello - I would appreciate some help with the following;
Brake Switch - Is the rear brake light switch unit painted black or a natural alum finish?
Chain - What is the correct or best chain to fit to the bike? The rear sprocket has 33-530 stamped on it.
72 T500 Questions
- Country: New Zealand
Re: 72 T500 Questions
Syd wrote:Brake Switch - Is the rear brake light switch unit painted black or a natural alum finish?
Any that I've seen have been just the natural aluminium finish.
A bit like asking for an oil recommendation It is a 530x110 L, so buy a bit longer. O and X ring will require a thin spacer behind the sprocket (a second lock washer usually works) so the chain will clear the plate on the cases.Syd wrote:Chain - What is the correct or best chain to fit to the bike? The rear sprocket has 33-530 stamped on it.
Thanks Ian
