T500 - Rear wheel hub washers
- Country: New Zealand
Hello - On the rear wheel, there are three curved metal tab washers (one for 2 nuts) that are used to hold the 6 nuts in place after the rear sprocket is fitted to the drum hub. Do you bend each tab end once up to each nut or bend each tab end more than once "around" each nut? A photo would be most helpful to show this if available - thanks.
Re: T500 - Rear wheel hub washers
Thanks for that - will give it a go..
