Can anyone advise where Item 37 = P/N 09403-00045 Clamp is located? I assume It is used to hold and cable or wire in place on the frame some where. If anyone has a photo of this in place, that would be great.
See; http://www.ozebook.com/compendium/T500parts/image30.htm" onclick="window.open(this.href);return false;
Mystery Location of Part T500-J
- Country: New Zealand
Re: Mystery Location of Part T500-J
Any ideas on where this part goes??
That's just one of the vinyl/plastic covered soft bendable metal wire clamps ? Normally on the early '70's twins they were found around the area of the rectifier just to catch the bundle of wires in that area and make it tidier.
Thanks for that - Yes you are correct about the material used for this. It is long at around +140mm and I was wondering where this would go - I'll check this out.
