Restoration T350
woertske
Country: Netherlands
Suzuki 2-Strokes: Suzuki T350
Restoration T350
Post by woertske »
I started with the disassembly of the bike.
Here you can see how it started
and what it is now
can anyone tell me how the flange is attached to the cylinder?
thanks in advance :up:
woertske
Re: Restoration T350
Post by woertske »
I started with the swingarm.
One of the bolds from de suspension was worn...
I cut them out
and replace them...
I think it will work out :)
Many happy hours of fun!!
Looking good so far.
woertske
Post by woertske »
Thanks Alan.. :up:
This week I received some parts through the post
T350 FRICTION CLUTCH PLATE SET
Two Suzuki T350 Carburetor Carb Repair Kits
SUZUKI T350 ENGINE GASKET SET
Left Side Cover
:mrgreen:
alanr
Post by alanr »
lots of work to do,what year is it because it has a lot of mixed parts. :up:
CB360T
TT250
woertske
Post by woertske »
On the paper it says: 1974!
I want to make a Custom/dirtbike or caferacer from it :mrgreen:
So I buy thinks for it what I like.... :up:
It wil take a year... I hope :roll:
woertske
Post by woertske »
I am in progress.. :D
New bearings in the front.. and painted everything
Packets from Canada...(Thanks Fred!!)
Forkseals, chain and sprockets are inn...
Forkseals are already in forks... picture will be uploaded this week. :up:
woertske
Post by woertske »
Frontforks....
Need only some sae30 for it... Or an alternative.
Someone here on the forum mentioned 15w30 :roll:
Now I want to do the wheels... it will take a wile because they are not so nice. :cry:
woertske
Post by woertske »
something on wheels... :lol:
The heads are for a '69 or '70.
Check the cylinder porting to see if you have '69 or '70 porting. The '70 has more ports.
Stock carb jetting is different for the '69 & '70 models.
See the service bulletins to determine stock jetting: http://www.ozebook.com/compendium/techbuls/index.htm
Have fun with your project. :up:
woertske
Post by woertske »
Thanks Jabcb for your info.. I am a beginner! So every info is welkom. :mrgreen:
I will look what type cilinder I have. :up:
dyrberg123
Country: Denmark
Suzuki 2-Strokes: T350 GT750 T125 RG250 RD125lc RD350lc RD400
Post by dyrberg123 »
Hi i have a couple of T350 so if you need any info i could be of some assistance. One of the is running with chambers, and keihin PWK carbs, 28mm. Runs like a dream. Also i have huge amounts of parts if you want me to look some port meassures etc up. Good luck. :up:
If it's not broken - don't fix it. Why not?
woertske
Post by woertske »
When I have some guestions... I will remember that dyrberg :mrgreen:
And I now for sure that they will come :up:
It's good to have some forum members who wants to help me out :D
Don't need to measure the ports to figure out which cylinder you have.
The later cylinder (70/71/72) has two auxiliary ports next to the exhaust port.
The early cylinder (69) does not have the auxiliary ports.
woertske
Post by woertske »
Here is a picture of the cilinder.
I think they are the later ones with two ports extra. :D
Jbcb you gave me a link for jetting.... but there are a lot of pages.
Can you help me out?( for these cylinders.) :oops:
