I'm trying to make sense of the bolts and washers needed to mount the front fender to the forks on my dragbike. According to the manual, it only shows a quantity of 1 bolt for the fork. I need 3 more and am trying to figure out which ones to get. The parts manual shows the following.....
1 Bolt 01221-08607
4 Lock Washers 08321-21088
1 washer 08322-11088
I think the 1 bolt might be for the 1 longer one. I would need 3 more bolts. Would they be part number 09100-08072 even though that part number shows for the J and K model and not the L and order 4 of the washers instead of 1?
Here's the page for the fender in the parts manual.
http://www.oldjapanesebikes.com//mraxl_ ... nders.html" onclick="window.open(this.href);return false;
Thanks for any help.
Bolts and washers for front fender on GT750L
- Herman T
- Country: U.S.
- Suzuki 2-Strokes: GT750 dragbike
Re: Bolts and washers for front fender on GT750L
You've found a typo in the parts manual.
J model has a fender for the 4LS drum brake. K & L models have same fender. K model info looks correct for K & L models.
Online parts info will provide current parts numbers: http://www.suzukipartshouse.com/#/Suzuk ... 6021180056
- Herman T
- Country: U.S.
Thanks for your help with this.
You can get bolts like that from your local hardware store at perhaps less than from Suzuki. I get much of my hardware from the local ACE.
