Just circling back to this topic again.
I recently found another chrome panel tanked Cobra - so a T500-I style Cobra - with frame 14271 and registered as a 1969. When I look at the various sites and also Rick's earlier comments, it looks like a possibility is:
- 1967 T500/5 from 10001 till some number - likely not higher than 11000 - had a 52 inch wheel base (short swing arm), chrome panels on the tank, button seat, rounder side covers and oil tank and deeper valanced rear fender. Also, the muffler cutout for the rear nut matched the short swing arm, so the exhaust is specific to this one model.
- 1968 T500-I - longer swing arm giving a 57.3 inch wheel base, still with the chrome panels on the tank, button seat, rounder side covers and oil tank and deeper valanced rear fender up to at least 14271 - assume about 16000
- 1969 T500-II - stainless seat trim, new style tank, stretched side covers and oil tank, shallow rear fender, carbs reduced from 34mm to 32mm - first frame number likely around 16000 and last frame number around 28000 ?
- 1970 T500-III - addition of luggage rack to tank and 'GT' style rear grab bar seen on the 1972 GT750 - possibly first frame number of around 28000 and last frame number of 30845
After the 1970 model year it continues to be confusing as of three sources I've checked there is no agreement - a guess is:
- 1971 R, 30846 - 46462 (build number of 15616)
- 1972 J, 46463 - 59578 (build number of 13316)
- 1973 K, 59779 - 68082 (build number of 8304)
- 1974 L, 68083 - 74161 (build number of 6079)
- 1975 M, 74162 -90728 (build number of 16567)
- 1976 A, 90729 - 104421 (build number of 13393)
- 1977 B, 104422 - 106765 ? This is the highest number I've seen so far (build number of at least 2343)
The above assumes that the numbering was contiguous.
For the earlier models between 1967 and 1971 it would be nice to get some photos of factory original bikes just to try and identify the model, with the frame numbers just to get a better idea of when the model changes actually did happen. For example, I have yet to actually see a 10 fin barrel, although several sites and the
Motorcycle Classics magazine state that was standard up till late 1969.
Thanks !
