Hi
The engine assembly on my 1972 500J has gone pretty smoothly. The transmission shafts and gear clusters were removed as units by the previous owner and don't appear to have been split into component parts. Everything went back in nicely in the cases and I was able to shift through the gears while the cases were open on the bench. I do, however, have a question regarding the transmission drive shaft.
The end of the shaft is visible in the clutch housing, however in mine the end of the shaft is not flush with the outer face of the "D" bushing, it is set back by about one millimeter. It just looks a bit odd and I don't know if this offset is correct.
The "D" bushing is installed with the "D" facing outwards and visible. Before I open up everything to check my assembly, can someone tell me if this recessed shaft is to be expected, or should the end of the shaft sit flush with the outer face of the bushing and I need to open the cases up again.
I tried to post a picture but don't seem to be able to get it uploaded; hopefully my explanation will be enough information to explain my dilemma.
Greatly appreciate any words of wisdom!
Many thanks
Andy
1972 500J transmission drive shaft question
- Suzuki 2-Strokes: 1972 Suzuki 500J
1946 WL45 Harley Davidson
1946 Norton 500 - Model 18
1960 BMW R60/2
1965 BMW R75/2 - project
1972 Suzuki T500J - winter rebuild
1973 Norton 750 Commando
1980 Moto Morini 500
1981 Ducati Pantah
1984 Yamaha FJ1100
1985 Yamaha FJ1100 - winter rebuild
1960 BMW R60/2
1981 Ducati Pantah
1984 Yamaha FJ1100
Re: 1972 500J transmission drive shaft question
I would need to see pics to compare it to my T500 motor.
Post your pics to an image sharing site. I use Flickr — it’s free & easy to use.
Then include links to those pics on your posts here.
Hi Jabcb
Thanks for the advice regarding Flickr. I have uploaded a photo that hopefully shows my dilemma...
https://www.flickr.com/photos/197518690 ... ed-public/
What do you think? Odd or correct?
Any advice appreciated!
All the best
Andy
All the best
Andy
1960 BMW R60/2
1981 Ducati Pantah
1984 Yamaha FJ1100
1960 BMW R60/2
1981 Ducati Pantah
1984 Yamaha FJ1100
There are alignment pins in the bottom crankcase half. If you properly engaged those alignment pins with the bearings/bushings/etc, then it’s is correct.
Also, it looks the same as in my build: https://flic.kr/s/aHsm9pLh8g
Thank you Jabcb, it is great to get your confirmation that my drive shaft offset looks normal.
I enjoyed your build photos on Flickr; you made an awesome job, the bike looks like it would be a blast to ride!
All the best
Andy
All the best
Andy
1960 BMW R60/2
1981 Ducati Pantah
1984 Yamaha FJ1100
1960 BMW R60/2
1981 Ducati Pantah
1984 Yamaha FJ1100
