Passenger Peg Vibration
- Suzuki 2-Strokes: 1970 T350 Restored; 1972 GT380 Build
Hello All. The passenger footpegs on the early GT380s vibrate horribly due to being the muffler attachment to the frame. Has anyone used a silicone or some other method to isolate the bracket from the mufflers to reduce some of the tingles? Thanks.
- joolstacho
Re: Passenger Peg Vibration
Don't think silicone would help - you have to tighten that stuff pretty tight, it'd just squeeze out of the joint.
If you could rig up a proper isolated rubber mount like one of those cotton reel rubber mounts (some exhausts use them) that could work.
Thank you, There is not much clearance on that exhaust mount, but will try something like that.
I cut some thin rubber to fit between the inner & outer brackets and this helped on my 550s.
Forum member markush has some pics of the exhaust mount.
See the links here: http://suzuki-gt380.de/gt380_dateien/Auspuff-Halterung/
Thank you.
