Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sun Jun 24, 2018 6:35 am
Post new topic Reply to topic  [ 13 posts ]
Author Message
 Post subject: Oil Pump Over haul
PostPosted: Tue Oct 31, 2017 9:04 am
Offline
Bikes owned: GT380
Hi Guys, new to the forum and would ask for help with my 1972 GT380 which is leaking 2 stroke oil, can someone point me in the direction in the forum that may show how to do the job and where I might get the gaskets etc.
Top
 Profile
 Post subject: Re: Oil Pump Over haul
PostPosted: Tue Oct 31, 2017 10:28 am
Offline
Where is it leaking?
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Yamaha 75 XS650
Top
 Profile
PostPosted: Tue Oct 31, 2017 10:37 am
Online
Country: WALES
Bikes owned: suzuki gt 550j
Welcome to the forum lots of good help on here
http://www.pinkpossum.com/GT750/Oilpump.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
This will help you understand the pump although its about the 750 the basics are the same.
These pumps are very reliable and dont often go wrong but as Jabcb says we need to know where it leaks?
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Tue Oct 31, 2017 12:29 pm
Offline
Country: England, UK
Bikes owned: FZ50, GP100, RG125 Gamma, GT380, Bandit 1200S
That's a great link, but where can you get replacement oil seals for these things? I would like to do a strip and rebuild of my own gt380 pump too, just to be thorough. So I will be watching this post with interest.
Top
 Profile
PostPosted: Tue Oct 31, 2017 12:51 pm
Offline
Bikes owned: GT380
I am having trouble pin pointing it but it is dripping down near the center stand, I have only just got the bike and the previous owner most definitely over filled the transmission which I have since drained.
Top
 Profile
PostPosted: Tue Oct 31, 2017 2:09 pm
Online
Country: WALES
https://www.discountbikespares.co.uk/ou ... GT125.html" onclick="window.open(this.href);return false;
Or
https://www.ebay.co.uk/itm/Genuine-Suzu ... Sw9GhYmaSM" onclick="window.open(this.href);return false;
_________________
Top
 Profile
PostPosted: Tue Oct 31, 2017 2:19 pm
Offline
It may actually be leaking from the connection between the oil tank & hose. The oil then runs down the hose & makes a mess of everything.
_________________
T500 73 project
T250 72
Yamaha 75 XS650
Top
 Profile
PostPosted: Tue Oct 31, 2017 2:31 pm
Online
Country: WALES
So we are sure its 2T engine oil and not 20\50 transmission oil?
If it is 2T there are several places it could leak. First place to Check is the oil sight window in the oil tank. They can sometimes weep from there. Then check the integrity of the connection of the tank to pump hose are the clamps good and tight? Then where the feed pipe banjo is bolted to the pump ensure there is a good gasket washer either side and the bolt is tight(be careful too tight and it will strip the thread) then ensure the pump is tight down on the oil feed pipe spider there are 3 phillips head bolts. The problem with oil leaks is its difficult to trace the source as the oil will run down and drip away from the leak.
Have a look here it may help
https://youtu.be/necW4LnXBHM
_________________
Top
 Profile
PostPosted: Tue Oct 31, 2017 4:15 pm
Offline
Bikes owned: GT380
Thanks Guys, I will start as suggested.
Top
 Profile
PostPosted: Tue Oct 31, 2017 6:21 pm
Offline
Bikes owned: Original owner GT550L
With the engine cold, spray it down with brake cleaner. Let it dry and dust it with baby powder. Let it sit overnight and check for leaks tomorrow. Oil leaks will show up in the baby powder as dark spots! Do the bottom of the oil tank, the hose down to the pump and the pump too.
If nothing shows up overnight cold, run the bike until it's warm/hot on the cener stand and have a look for leaks.
Cliff.
Top
 Profile
PostPosted: Wed Nov 01, 2017 8:46 am
Offline
Cliff.
Thats excellent. I like the baby powder trick! Not heard of that before.
Top
 Profile
PostPosted: Wed Nov 01, 2017 7:54 pm
Offline
Helps prevent monkey butt too!!
Top
 Profile
PostPosted: Thu Nov 02, 2017 1:20 pm
Offline
Spray brake cleaner on your butt first?
Top
 Profile
Who is online
Users browsing this forum: No registered users and 12 guests
Search for:
Jump to:
cron
Suzuki2Strokes.com
