Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Fri Jun 22, 2018 7:20 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: Sat May 27, 2017 11:41 am
Offline
Bikes owned: 1968 T20
Hey,
I have a conundrum.
2 cylinders ... 2 pistons.
I know that the arrow point forward... but does one piston go into a specific cylinder?
When I took them out they were thick with carbon!!!
Now that they are cleaned up I notice that one has an "E" and one has an "F".
Does it matter? Other than they were in there for a long time?
_________________
"Some people know, and other's want to... Progress happens when you understand when to be who!"
Top
 Profile
PostPosted: Sat Jul 22, 2017 1:10 pm
Offline
Country: England, UK
Bikes owned: FZ50, GP100, RG125 Gamma, GT380, Bandit 1200S
Are they both the same size?
Do they both have the ring locating pins in the same place?
Do they have any holes in different places?
If the answers are, yes, yes and no, then they are interchangeable.
However, as a general rule it is advisable to always make a note of which bore they came from and put them back in the same bore.
This is so that the rings and pistons are matched to the bore they have been bedded into. If you are fitting new rings, it is less important.
Are you fitting new rings?
If so don't forget to hone the bores of the barrels.
Top
 Profile
PostPosted: Sat Jul 22, 2017 5:17 pm
Offline
Per the parts diagram there is only one part # for each of the sizes (standard, oversize 0.5 & oversize 1.0). So there is no left & right — they are the same.
Paul Miller has a NOS set of 1st over pistons. One is labeled “0.5” & the other is labeled “E”.
http://www.ebay.com/itm/Suzuki-T20-TC250-nos-1st-over-piston-and-ring-set-1966-68-/381542745159
But another seller has a set of standard pistons labeled with “E”.
http://www.ebay.com/itm/Suzuki-T20-TC250-X-6-Piston-STD-Set-x2-NOS-GENUINE-JAPAN-12110-11600-/262397853199
So your “E” & “F” might indicate different sizes.
Accurately measure your pistons + cylinders, and you should be able to sleuth this out.
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Yamaha 75 XS650
Top
 Profile
PostPosted: Sat Mar 31, 2018 3:58 pm
Offline
Hmph...
Thanks jabcb...
They are in the cylinders now... So I either got lucky and put them back the same...
Of one is too tight.
I will do some accurate measure.
The cylinders were honed.
_________________
Top
 Profile
PostPosted: Sat Mar 31, 2018 5:04 pm
Offline
Country: Wales
Bikes owned: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Check that the ring gaps are not travelling over the ports.
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 5 guests
Search for:
Jump to:
cron
Suzuki2Strokes.com
