Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Dec 13, 2018 10:19 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
 Post subject: Air Boot Issues
PostPosted: Sun Mar 27, 2016 5:55 pm
Offline
Bikes owned: GT750(Jx3,L,M,A,B),T500
I was having trouble fitting the inlet air boot on the 1972 J I just finished, and then realised what the problem was. The inner sleeves had come loose. Anyone else seen this ?
So when I tried to slip the end over the carb inlet, it was just pushing the sleeve back into the boot. When checking the other two, the middle one was half loose and easily pulled out. I suppose after 45 years or so, glue can start to fail. So I pulled out my spare - and found on it all three were loose. This is a photo with all three sleeves removed from the spare inlet air boot. :?
I've tried some silicon, and also some Gorilla glue - so far the Gorilla glue is a bust. I was thinking of model aircraft super glue, but the neck has to flex as well as stretch slightly , so I don't think that anything that sets hard will work. And no - pods are not an option for me. Just personal choice as I don't like how they look.
Suggestions appreciated. 8)
_________________
Top
 Profile WWW
 Post subject: Re: Air Boot Issues
PostPosted: Mon Mar 28, 2016 12:37 am
Offline
Country: United Kingdom
Bikes owned: T500_MKIII
Rubber contact adhesive like evostick?
Top
 Profile
PostPosted: Mon Mar 28, 2016 8:48 am
Offline
Bikes owned: 1972 T250 1976 GT500A(sold)
I'd also try tire/tube patch adhesive. Its made to glue rubber patches to rubber inner tubes. So it should work.
Relic
_________________
1976 DT400C -daily rider
1972 Suzuki T250 Hustler - daily rider
1974 Moto Guzzi Eldorado sidecar outfit -daily driver
1971 Hodaka Ace 100 B+ daily rider
Top
 Profile
PostPosted: Mon Mar 28, 2016 9:28 am
Offline
Country: United States
Bikes owned: 1979 Yamaha XS650, 1974 Suzuki GT550
Silicone Caulk?
Top
 Profile WWW
PostPosted: Thu Mar 31, 2016 4:10 am
Offline
Goop will work. I have repaired lots of rubber stuff with goop.
_________________
Top
 Profile
PostPosted: Fri Apr 01, 2016 11:32 am
Offline
Thank you for the suggestions - I have a couple of options I'm testing and will let folks know how they work. 8)
_________________
Top
 Profile WWW
PostPosted: Tue Nov 29, 2016 9:54 am
Offline
Bikes owned: '72 gt750
How critical are these horns inside the boot? I don't have the boot in front of me and haven't seen it for a while now but it seems to me they aren't in the boot. I need to double check this.
OJB, how are they supposed to sit in the boot? I am guessing the very front edge of the horn should be flush with the very front edge of the boot, so that the clamp secures the boot, and horn onto the carb mouth?
_________________
'72 GT750
Top
 Profile
PostPosted: Tue Nov 29, 2016 6:28 pm
Offline
Correct - basically without the bell the ID is a bit too big on the boot for the inlet bell of the carburettor. I suppose also that the horns help manage the airflow into the inlets. Goop seems to be working so far as an adhesive. 8)
_________________
Top
 Profile WWW
PostPosted: Tue Nov 29, 2016 8:56 pm
Offline
Right, I was assuming the same. I just went out to the shed to check, I must have misremembered because my boot has the 3 horns intact.
_________________
'72 GT750
Top
 Profile
PostPosted: Wed Nov 30, 2016 4:19 am
Offline
Goop is one of my favorites. Good for many things, as it sticks to nearly everything.
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 16 guests
Search for:
Jump to:
Suzuki2Strokes.com
