T500 Serial Numbers
- Suzuki 2-Strokes: T500
T500 Serial Numbers
Hi.I want to restore a T500 I have owned since 1976. purchased it for a carton of beer and kept it since. I can't find the year of manufacture on the identification plate nor the serial number on any web sites. The matching frame and engine numbers are 30173. I was missing the fuel tank when i picked it up so if I can identify the year I can get the right parts.
- Fritz500
Re: T500 Serial Numbers
Have a look here: http://home1.stofanet.dk/cssdk/modelller1gb.htm" onclick="window.open(this.href);return false;
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
- ConnerVT
- Novice racer
My best guess this morning is 1970. Still drinking my first cup of coffee.
No tank, but does it have the side cover or oil tank badges? If so, that and color (if still stock) would help.
Based my guess on the following:
viewtopic.php?f=8&t=4639&p=114679&hilit=serial#p114679
http://suzukits.informe.com/wiki/view/S ... _1971-1981
The bike should be a T500 Mark3 1970 or around then
Suzuki GT750A
Thanks for that. The colour is sort of gold. Faded a lot, but goldish. The bike was used as a racer. The mechanic had it in pieces under his bench. Only the oil tank remained with colour. I have purchased new bars, instruments,Cables and covers over the years but never confirmed the year. Put it all together and rode it once. proceeded to pull it down again to restore it. And here I am 38 years later getting back into it. The new parts look identical to the old but I probably now have a bitser. I do have the original guards and exhaust. Probably not worth the effort financially but why keep something that long and then toss it. Will post photos as it goes together if you wish.
- ConnerVT
- Novice racer
If it is the stock paint (Candy Gold), another indication that it is likely an early 1970 T500.
http://www.suzukicycles.org/T-series/T500_models.shtml
Late MK3 - see this link where I have cited the sources:
http://www.oldjapanesebikes.com/mraxl_G ... ne_id.html" onclick="window.open(this.href);return false;
- Fritz500
oldjapanesebikes wrote:Late MK3 - see this link where I have cited the sources:
http://www.oldjapanesebikes.com/mraxl_G ... ne_id.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I have a couple of T500s with matching engine and frame numbers:
- T500J -55683
- T500K -60819 (build date Sept/72)
You can add these to your list.
Geoff
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
Thank you and done !Fritz500 wrote:You can add these to your list.
