Archived Posts
Admin
Supreme UFOB
Removing Suzuki tank badge
Post by Admin »
Hi, I was wondering if anyone can tell me how to remove the Suzuki tank badge off a 1972 GT750? There don't appear to be any screws holding it in place, unlike a 1975 model I had which had 2 small screws. thanks
Admin
Supreme UFOB
Post by Admin »
It snaps on with two little doohickies that Suzuki called "nuts". You have to carefully pry it off. You WILL bend it, but it bends back easily.
Admin
Supreme UFOB
Post by Admin »
Lane --as always -- is quite correct. You can re-apply it with two-sided auto tape.
(And the '75 has to be pried off, too. It's the '76 and '77 are held on with screws. Not that I'm anal or anything......)
Admin
Supreme UFOB
Post by Admin »
I pried mine off and one of the holes in the bracket on the tank is wallowed out too big to hold the small clip or nut or whatever it is called. Will the double sided tape hold it on securely or do I have to figure out a way to fix the d$mn hole? What about putting some kind of adhesive (Black RTV maybe) in the hole and sticking the stud into it?
Also, are the clips still available, all mine were toast by the time I got them off.
Wayne
Admin
Supreme UFOB
Post by Admin »
Wayne, I use double-sided automotive emblem tape, and have never had a problem.
Admin
Supreme UFOB
Post by Admin »
thanks fellas
Admin
Supreme UFOB
76' GT500 mirror shock mounts found CHEAP!
Post by Admin »
I baught the mirror shock mounts from suzuki for $12.00 but just run up on mounts at JC Whitney!!! for $4.99 plus shipping!!!! AAaarrrrgggg!!!! Dont know if anyone uses them but they are for 10mm standard thread. JC W part number CAW060517 I had them on the 76' GT500. Now if I can only find good fork dust covers to fit. Dofin
Admin
Supreme UFOB
Throttle cable part number check
Post by Admin »
Can anyone tell me what model this throttle cable goes on:
P/N: 58300-30700
I bought it off eBay with the description of TS250 throttle cable. When I received it today, I was bummed that it is a single pull cable and too long even to be the top half of my '74 TS250 cable.
Thanks for the help!
Chris
Admin
Supreme UFOB
Post by Admin »
That one has been Discontinued for a While now.It doesn't show the Application on any of my Microfiche. :? Let me get the Part number for the One you need I may just have one.
Admin
Supreme UFOB
Post by Admin »
Chris looks like the Part Number you need is 58300-30000 or 30001 or 30002.They are still Available at the Dealer for Around $27.I may Accidentially Have one and will look tomorrow.
Admin
Supreme UFOB
Post by Admin »
Thanks for the info Jughead!
Yeah, I should have asked for the part number prior to bidding and winning the auction...
Anyone need a 58300-30700 throttle cable? :shock:
I checked Ron Ayers and it looks like they carry the proper throttle cable for just over $20. Let me know if you find anything in your stash. I really appreciate the help.
Thanks,
Chris
Admin
Supreme UFOB
Post by Admin »
i'm pretty sure you can call Color-Rite at 1-800-736-7980 with those color codes and get the paint. at least that's what i'm trying to do for my '72 T500J (green/white).
do you show my codes in your parts book? i think the green is called Vernado Green... what are my codes?
Thanks!
Admin
Supreme UFOB
Post by Admin »
You fellows need to get OGRI on this -- he's a genius at it.
Admin
Supreme UFOB
Post by Admin »
For '72 the colors were "Pure White" #064, "Candy Verdoro Green" #263, and the other choice was "Pearl Orange" #264.
Are you guys planning to paint the parts yourselves? I got a quote for the two tanks and side cover for $750. I know a man's got to make a living, but that's how much I paid for the whole bike!
The other choice is to paint the '72 myself with rattle cans, but I'm concerned the paint gets damaged by gasoline. Is this true? Can you clear coat with lacquer or something?
Thanks,
Tom
Admin
Supreme UFOB
Post by Admin »
Oh no no no, rattle cans are not going to do for a tank coming into contact with gasolene spills however slight they may be, all except for a few basic colours (some black and white enamels) in a few brands can tolerate gasolene for a while, but whos going to paint their tank in all white or black.
Its best to bite the bullet and have the coloured parts profesionally done in the correct colour, thats of course if you think your bikes worth it.
On average to have a tank,side covers,headlight bowl and ears painted, including the parts is about $750.00, not too bad when you think about the cost and labour involved.
