In for a pound
kawonda750
Country: canada
Suzuki 2-Strokes: 1965 Yam74 gt550, 75 GT750 M, 2019 Kaw Z900RS
Re: In for a pound
Post by kawonda750 »
On to my next problem..
The starter worked in the fall before the engine came out. I had to replace the start button first but after that it did turn the engine. After re-assembly, all I got was the clicking of the solenoid so I replaced the solenoid with a new aftermarket one. All I get with the new solenoid is the same clicking. Battery is fully charged and reading 12.91 Volts.
Any suggestions?
badgereng
Suzuki 2-Strokes: GT500A - 1976
Re: In for a pound
Post by badgereng »
Try a different battery first….
Connect battery direct to started to isolate the button / wiring.
If that doesn’t work, pull the starter motor out and try spinning it over whilst not engaged to the engine.
kawonda750
Country: canada
Re: In for a pound
Great. Thank you ...again
karl pa
Country: us
Re: In for a pound
Post by karl pa »
Do you have a good ground wire and connection from frame to engine? The engine is mounted with rubber mounts.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
kawonda750
Country: canada
Re: In for a pound
I have the braided ground wire at the left back from the 10 mm top case bolt there to the frame. All other electrics work, lights signals, horn so I assume the ground is good. I will check it again and make sure the connection is clean and tight to be sure.
karl pa
Country: us
Re: In for a pound
Post by karl pa »
All lights and horn use the ground of the frame so they will work anyway. If the ground is good, use a volt meter on the starter side of solenoid, if it shows 12 volts you have an issue with starter or cable. Check battery voltage while pressing start button, if it drops low you could have a weak battery or a mechanical bind.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
kawonda750
Country: canada
Re: In for a pound
Turns out it was the cable connection at the starter. Working well now. I would be tempted to switch to pod filters if I had to struggle with this airbox a number of times. It doesn't help that the rubbers are cold in my garage and stiff. I use my wife's hair dryer to soften them up and make them a little more flexible.
Thank you for all the input. I've had enough for today. Back together tomorrow.
badgereng
Re: In for a pound
Post by badgereng »
Troubleshooting gets easier if you keep it as simple as possible.
Break the problem down into its component parts / systems / subsystems and you won’t go far wrong.
If it was working fine before, you don’t need to stray too far.
Too many people tend to go way off tangent and introduce more fog than was initially present.
Glad you found it quickly.
karl pa
Country: us
Re: In for a pound
Post by karl pa »
The problem with (it was working before) the engine was removed and rebuilt and reinstalled, that opens the problem to more possibilities
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
kawonda750
Country: canada
Re: In for a pound
Another small roadblock on the way to the return to the road. It seems that I am missing the spacer that goes on the sprocket side of the rear wheel. I couldn't mount the chainguard after replacing the aftermarket rear shocks with stock ones. There was no room at the wheel. Checked the parts listing and saw what was missing.
I guess the enclosed chain guard that I removed had that built in. So , again, it is hurry up and wait for the specer to arrive from England. Hoping this is the last surprise. I am still waiting for the tank and covers from the painter too.
kawonda750
Country: canada
Re: In for a pound
Finally getting there. The painter had the tank scanned and a close match for the original grey metallic is Suzuki 511 ZDL. Hopefully it will be finished by late next week.
