Oil Pump Over haul
abs268
Suzuki 2-Strokes: GT380
Oil Pump Over haul
Post by abs268 »
Hi Guys, new to the forum and would ask for help with my 1972 GT380 which is leaking 2 stroke oil, can someone point me in the direction in the forum that may show how to do the job and where I might get the gaskets etc.
Re: Oil Pump Over haul
Where is it leaking?
GTandcbr
Country: WALES
Post by GTandcbr »
Welcome to the forum lots of good help on here
http://www.pinkpossum.com/GT750/Oilpump.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
This will help you understand the pump although its about the 750 the basics are the same.
These pumps are very reliable and dont often go wrong but as Jabcb says we need to know where it leaks?
98 carb Blackbird and GT550j
sportston
Country: England, UK
Post by sportston »
That's a great link, but where can you get replacement oil seals for these things? I would like to do a strip and rebuild of my own gt380 pump too, just to be thorough. So I will be watching this post with interest.
abs268
Post by abs268 »
I am having trouble pin pointing it but it is dripping down near the center stand, I have only just got the bike and the previous owner most definitely over filled the transmission which I have since drained.
GTandcbr
Country: WALES
Post by GTandcbr »
https://www.discountbikespares.co.uk/ou ... GT125.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Or
https://www.ebay.co.uk/itm/Genuine-Suzu ... Sw9GhYmaSM" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
It may actually be leaking from the connection between the oil tank & hose. The oil then runs down the hose & makes a mess of everything.
GTandcbr
Country: WALES
Post by GTandcbr »
abs268 wrote:I am having trouble pin pointing it but it is dripping down near the center stand, I have only just got the bike and the previous owner most definitely over filled the transmission which I have since drained.
So we are sure its 2T engine oil and not 20\50 transmission oil?
If it is 2T there are several places it could leak. First place to Check is the oil sight window in the oil tank. They can sometimes weep from there. Then check the integrity of the connection of the tank to pump hose are the clamps good and tight? Then where the feed pipe banjo is bolted to the pump ensure there is a good gasket washer either side and the bolt is tight(be careful too tight and it will strip the thread) then ensure the pump is tight down on the oil feed pipe spider there are 3 phillips head bolts. The problem with oil leaks is its difficult to trace the source as the oil will run down and drip away from the leak.
Have a look here it may help
https://youtu.be/necW4LnXBHM" onclick="window.open(this.href);return false;
abs268
Post by abs268 »
Thanks Guys, I will start as suggested.
Cliff56
Post by Cliff56 »
With the engine cold, spray it down with brake cleaner. Let it dry and dust it with baby powder. Let it sit overnight and check for leaks tomorrow. Oil leaks will show up in the baby powder as dark spots! Do the bottom of the oil tank, the hose down to the pump and the pump too.
If nothing shows up overnight cold, run the bike until it's warm/hot on the cener stand and have a look for leaks.
Cliff.
sportston
Post by sportston »
Cliff56 wrote:With the engine cold, spray it down with brake cleaner. Let it dry and dust it with baby powder. Let it sit overnight and check for leaks tomorrow. Oil leaks will show up in the baby powder as dark spots! Do the bottom of the oil tank, the hose down to the pump and the pump too.
Cliff.
Thats excellent. I like the baby powder trick! Not heard of that before.
Cliff56
Post by Cliff56 »
Helps prevent monkey butt too!!
sportston
Post by sportston »
Cliff56 wrote:Helps prevent monkey butt too!!
Spray brake cleaner on your butt first?
