Media Blasting GT750 Cases
- water cooled
Re: Media Blasting GT750 Cases
Dave, going over all the internal parts. Output shaft threads had an issue, clutch basket was in rough shape and was replaced, water pump gear was upgraded to aluminum (with the help of a board member) kick start spring replaced, shift bearing replaced. Crank rebuilt by Josh and Flannery has the block and Wossner pistons for fitting. Frame is getting some small mods and hopefully a decent paint job
I look forward to seeing you this race season then with the all new Hatchet Bike
I wish i had done up a second GS transmission to have you try if you wanted to . I think the Aus. Bob thats coming here to race may be running the GS tranny ?
- water cooled
I think Bob is going to race the MI built Altered GT so I believe it has a stock transmission set.... although you never know what Fortino is going to slip in there before May.
Oh .. thats right he is having one built here .
