Disc brake conversion
Getting your chassis to handle your blazingly fast Suzuki powerplant.
pull the wire
Country: united states
Suzuki 2-Strokes: 73GT750 75GT750 84RZ350 89 FXRS-CONV
Re: Disc brake conversion
Post by pull the wire »
A little progress. The GS100 swingarm is actually about 3 inches longer than stock GT750. It looks great. I'm going to lower the front an inch and 13.5 rear shocks Funds are tight right now so I do what I can. Does anyone have 13.5 inch clevis style shocks????
You gotta pull the wire to go fast
pull the wire
Yes good progress on the disc conversion. I found a set of 1200 bandit foot controls with the shifter and rod, the brake pedal and master cylinder. Without much welding they fit and look great. I used the passenger foot peg mount as the primary mounting point on both sides so they are very evenly set to the rear and balanced side to side. It was almost too easy and no where near the price of bolt on rear sets :D . I've been unable to attach pictures because I'm a dumb A__ and can't remember how to do it
attach pictures info viewtopic.php?f=1&t=3098" onclick="window.open(this.href);return false;
pull the wire
The center mounting hole on the 1200 Bandit foot controls is fastened to the passenger foot peg mounting point. All I have to do is fab up a couple brackets for the other 2 mounting holes on the Bandit foot controls. The shift linkage is spot on and reverses the shift pattern which sounds fun. The brake linkage, master cylinder and brake switch are all tucked in nicely and have no clearance issues. The seating and foot control positions are comfortable.
I am trying to attach photos that are within the 750kb limit but the warning message says "Sorry, the board attachment quota has been reached"
Maybe I'm stupid but I just can't get any photos to attach
