GT750 Swingarm Bushings
More help guys, I've heard that the partsnmore swingarm bushings won't fit the buffalo but I emailed them and they said that they were a direct bolt on fit. Can anyone confirm this? The stock bushings didn't seem that bad but I might as well put this thing back together as tight and new as possible - especially steering - suspension and brakes.
So many Projects - So little time
Re: GT750 Swingarm Bushings
I agree that's what they say, but they are wrong. I had to have my last set turned down on the OD to get them to fit and they still had to be reamed to size after they were pressed in.
I was afraid of that. I guess I'll try the needle bearing mod you have graciously posted on your pinkpossum page. It doesn't look too bad and I'm guessing it's a lot better than using stock bushings.tz375 wrote:I agree that's what they say, but they are wrong. I had to have my last set turned down on the OD to get them to fit and they still had to be reamed to size after they were pressed in.
- oldjapanesebikes
I (and lots of other folks here in Calgary) had the same problem Richard mentions with the PartsnMore bushes - there is no way in hell they will fit without modification. I have installed Richard's needle roller bearing conversion idea on my '73 - not hard at all and I'm pleased with it - I wrote about it here.markj wrote:I was afraid of that. I guess I'll try the needle bearing mod you have graciously posted on your pinkpossum page. It doesn't look too bad and I'm guessing it's a lot better than using stock bushings.tz375 wrote:I agree that's what they say, but they are wrong. I had to have my last set turned down on the OD to get them to fit and they still had to be reamed to size after they were pressed in.
So two of these is all I need + cutting the old fiber cups as flanges?
http://www.amazon.com/Torrington-B-1412 ... =8-2-fkmr0" onclick="window.open(this.href);return false;
- oldjapanesebikes
Two on either side, so four in total.markj wrote:So two of these is all I need + cutting the old fiber cups as flanges?
So with everything cleaned I test fitted the needle bearings with the axle and bushings and I found it's a little looser than I thought. I'm a little concerned that over time that play could hurt the bearings but I'm no engineer so i don't know.
- Novice racer
- Suzuki 2-Strokes: gt750
partsnmore dont seem to be listing the swingarm (bronze) bushes any more.
and i cant seem to find an alternative sorce.
any help would be appreciated.
cheers mark
cheers mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
1985 RZ350N
- Suzuki 2-Strokes: T500, RSV1000r, CBR600F4i
not to hijack, but i was reading your site Ian and wholy crap!!! that garbage tyre trick is awesome!!!!!!!!!!!!
- oldjapanesebikes
I had the same thought, but once I had everything bolted up it actually felt fine. Time will tell I suppose, and you could well be correct - although I can't help thinking that the hardened steel rollers will last longer than the fibre bushesmarkj wrote:So with everything cleaned I test fitted the needle bearings with the axle and bushings and I found it's a little looser than I thought. I'm a little concerned that over time that play could hurt the bearings but I'm no engineer so i don't know.
I agree. I'm sure it's better than the stock setup.oldjapanesebikes wrote:I had the same thought, but once I had everything bolted up it actually felt fine. Time will tell I suppose, and you could well be correct - although I can't help thinking that the hardened steel rollers will last longer than the fibre bushesmarkj wrote:So with everything cleaned I test fitted the needle bearings with the axle and bushings and I found it's a little looser than I thought. I'm a little concerned that over time that play could hurt the bearings but I'm no engineer so i don't know.
- oldjapanesebikes
Thanks, but I can't take the credit for the trash bag trick - that was posted by diamondj some time ago on the board at this link. It is a pretty cool way to mount a tire - make sure you get a really thin bag as I found that to be best.crash277 wrote:not to hijack, but i was reading your site Ian and wholy crap!!! that garbage tyre trick is awesome!!!!!!!!!!!!
