Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Mon Jan 21, 2019 11:06 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
Author Message
 Post subject:
PostPosted: Sun Nov 16, 2008 1:43 pm
Offline
From what I can see from the parts lists, it appears that the 72 forks are a "shuttle valve" design rather than "damper rod" so they can't be easily modified to use these.
Can anyone confirm that please?
Top
 Profile
 Post subject:
PostPosted: Sun Nov 16, 2008 2:02 pm
Offline
Cool, thanks. I'll have to read a bit more about front shock setups as I don't know much about them.
Arne
_________________
1981 Honda CB750-1000 driver
1982 Honda GL500 easy project
Top
 Profile
 Post subject:
PostPosted: Sun Nov 16, 2008 6:08 pm
Offline
The early forks were referred to as "Ceriani-type". They are very different. If they are really copies of Cerianis, they shouild be pretty good.
_________________
Top
 Profile
 Post subject:
PostPosted: Sun Nov 16, 2008 6:35 pm
Offline
The 72 GT750 forks are fine, relatively. It's the shox that sux!!!!
Top
 Profile
 Post subject:
PostPosted: Tue Dec 02, 2008 6:55 pm
Offline
When I fitted the cartridge emulators and assembled the forks there was a lot of stiction with NOS LeakProof seals, so I just stripped the forks and fitted a pair of new seals from Mike's XS along with a pair of seal washers and fork boots.
What a difference - at least in static mode. We'll know in spring when the snow recedes if they are an improvement in the real world, but I have high expectations.
Top
 Profile
 Post subject:
PostPosted: Tue Dec 02, 2008 7:33 pm
Offline
I just bought a set of the emulators, myself. Eventually, I'll get around to installing them!!!
By the way, "Leakproof" seals are the only seals I've ever had problems with: they suck!!! Stay with OEM.
_________________
Top
 Profile
 Post subject:
PostPosted: Tue Dec 02, 2008 10:51 pm
Offline
Lane,
I know, I know.
They were old and lying on the shelf so I thought "why not", after all the only two times I used leakproof seals before, they were a total disaster so third time was supposed to be lucky. :cry:
They are now appropriately filed in the garbage bin.
Top
 Profile
 Post subject: Re: Fork mods
PostPosted: Sun Jul 31, 2011 11:10 am
Offline
Bikes owned: rz350;cb750ss;gt750
Old thread I know, But is everything functioning properly.
I read somewhere else the forks became to stiff with oil in them.
Have there been revisions since this thread was created?
thanks guys
Top
 Profile
PostPosted: Wed Aug 24, 2011 2:49 pm
Offline
Yes. After I fitted the adapters things started to clear up and now they move nicely. They are fairly stiff but I took a lot of weight off the bike and didn't adjust spring rates for that change.
They should be fine as they are now.
Top
 Profile
PostPosted: Thu May 14, 2015 10:24 pm
Offline
Country: usa
Bikes owned: GT550, GT750, 80 RM400, 80 RM250, TL1000R,
Hi TZ375, Would you mind sharing your current fork setup?
My GT550 suspension, for a better lack of words, sucks! Forks have fresh seals and oil and the are so soft under damped and springing that its dangerous. Shocks not much better but that is pretty easy to fix. Just buy good shocks.
Anyways thanks for your input.
Top
 Profile
PostPosted: Tue May 26, 2015 4:04 am
Offline
Country: Germany
Bikes owned: GT250/380
Hi!
another mod: air support at GT380-Fork
see also:
http://www.mariolange.de/wbb2/thread.php?postid=12083#post12083
( https://translate.google.de/translate?hl=de&sl=de&tl=en&u=http%3A%2F%2Fwww.mariolange.de%2Fwbb2%2Fthread.php%3Fpostid%3D12083%23post12083 )
Markus
_________________
http://suzuki-gt250.de
Top
 Profile WWW
PostPosted: Tue May 26, 2015 8:38 am
Offline
Set up now is two inches shorter than stock to lower the bike for drag racing :shock: But the original forks have Emulators sitting on a short spacer to allow oil to pass around the adjuster nut. Damper rods were drilled out as normal for emulators and I also brazed the small rebound damping holes and redrilled them to work with the Progressive Suspension fork springs. I also use a stiff fork brace to stiffen the front end up a bit.
They are still heavy and small and not anywhere close to modern forks but they seem to be much better than they were. If you need to buy a set of sliders for a second disk, it might be smarter to look into an SV650 front end. The older models look much like a GT and you could use a GT hub with SV disks and calipers but would probably need spacers to get the disks in the right place relative to the calipers.
I have not measured a set of SV forks but that may be the way to make a huge difference.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 5 guests
Search for:
Jump to:
Suzuki2Strokes.com
