Archived Posts
- Supreme UFOB
I personally dont like ATF for any application in rear shocks or forks, i find its too "edgy" and offers no real lubing properties.
Bel Ray make fork and shock oil in various viscosities which offer superior performance to ATF or regular oil.
For years ive used this in all my motocross bikes with no seal leakage or noticable wear, also you can play around with the viscosity grades to alter the rebound and damping properties, especially useful on forks that dont carry any external adjustments.
- Supreme UFOB
Good question on the oil viscosity needed for the buffalo Lane,and until i rebuild and test the A model forks i have, i cant tell you this final figure yet.
Looking at the ATFs viscosity i'd say that the minimum fork oil to even consider in the Buffalo is the 7 weight, although i think the 10 would hardly be way too stiff either, considering the overall soft nature of vintage forks with very little in terms of proper damping.
This general spongy performance was commonly called the "pogo stick" effect back in the days of when testing these bikes.
For my A model forks i still need to get my new upper stancions which will soon be here, some new piston rings for the lower inner rods and paint the alloy outer legs in a decent metallic silver with clearcoat.
I cant stress enough that its a common myth, that by raising the oil level significantly the overall hydraulic action will stiffen up.
Definately it will for a while till you over pressurise the system internally and 'blow' the seals, then its back to another rebuild.
I also have some progressivily wound fork springs to add into the mix, so these will also affect the overall compression and rebound damping action along with me playing with the viscosity values.
I had heard about the mod with blocking some hole recently, but havent persued it, so which hole are they referring to.
- Supreme UFOB
- Supreme UFOB
One rule of thumb for all standard type front forks is, you want to take a look down the tube. With the lower leg slider filled with oil, fork fullly extended, you want one inch of fluid above the top of the damper. The damper is that aprt the spring sits in, and the part you can see in the center of the tube.
Oil gets pushed up into the spring, and doesn't drain down as fast as we think, so...the oil level needs to be high enough to not uncover the top of the damper.
- Supreme UFOB
damper rod mod
i did my fork seals today. it's amazing how much crap gets in there in one season. while i had it apart i braised the top orifice. i read somewhere that there is three orifi but mine only had two. i braised it anyway but now i'm wondering if i shouldn't have. the front end felt really washy last summer so it should be better but i don't want to pop the new seals. any comments?
- Supreme UFOB
Advant,
The article is here:
http://www.ozebook.com/compendium/suzi/mags/forks.htm
and the info you want is here:
http://www.ozebook.com/compendium/suzi/mags/forks2b.jpg
There should be two rebound damping holes at the top that you reduce to one and one compression damping hole at the bottom that you leave alone. Don't forget the 1 inch spacer between the damper rod and the cone at the bottom.
Jim
Jim
- Supreme UFOB
for lack of the proper length allen bolts i put the spacer mod on hold. it will be a good test bed though to see how the front end reacts doing the mods in stages. if the spacer lifts the damper rod (as well as compressing the spring) does that mean more fork oil is required to cover the damper rod?
- Supreme UFOB
I haven't altered the bottom hole on any I've done. You've done well; it'll work fine. I added the spacer to one set of forks, and honestly haven't noticed any significant difference from the added travel. Maybe if I start jumping the bike, it'll matter...... I've done two sets without the added spacer.
