T500
stevebee
Country: australia
Suzuki 2-Strokes: t500 kawasaki z900 harley davidson flsti
T500
Post by stevebee »
Can anyone help Does a gt380 gt550 or gt750 triple tree fit a t500
Re: T500
You can certainly use the 750 stuff.....I wouldn't be suprised if the other two are the same, but I haven't had experience of those.
Re: T500
All Balls Racing has a lookup tool that shows what bearings you will need.
https://www.allballsracing.com/index.php/forkconversion
The steering stops that prevent you from turning too far are different on the T500 & GT-series bikes.
You’ll need to make new stops & weld them to the frame.
My T500 cafe build has a GT500 triple tree & will have GS-series fork tube assemblies.
The project is proceeding slowly & I plan on designing the stop in the next few weeks.
stevebee
Country: australia
Re: T500
Post by stevebee »
thanks for your help.
Re: T500
The T500 triple tree uses ball bearings on the steering stem. The tapered roller bearings listed in the All Balls guide are a little longer (in the axial direction). This lowers the bottom triple tree a few mm. Be sure to take this into account when positioning the new steering stop.
