Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Apr 18, 2019 11:20 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Fri Sep 29, 2017 5:43 am
Offline
The online parts diagrams do not show a damper rod.
This old topic refers to the forks as possibly being a “shuttle valve” design: http://www.suzuki2strokes.com/forum/viewtopic.php?f=7&t=161&hilit=gt550+fork+springs&start=15
What is a “shuttle valve” design?
Am working on the forks for the GT550 cafe project.
The forks actually have damper rods, or at least they look like damper rods with 8 small holes.
The service manual has a drawing of the forks. The “damper rod” is labeled as a “spring seat”. And the inner tube has a “Valve”.
Damper rod:
ImageGT550-forks-0692 by jabcb, on Flickr
Service manual drawing:
ImageGT550-forks-0694 by jabcb, on Flickr
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Sat Sep 30, 2017 9:36 am
Offline
Shuttle valve was a term used by Triumph when they changed to that design of damping. It means that the piston and/or valve at the bottom of the legs is free to move up or down to alter the available orifice area. When the forks move, the valve also moves a small amount and partially covers or uncovers a ring of holes through which the oil moves and that's where the damping comes from. In one direction the holes are more covered than the other direction and hence different damping in compression and rebound.
On Triumphs, I think the piston was also the valve and moved but on a GT550 IIRC the piston is fixed and only the valve moves.
Not easy to change damping on those except by changing oil and they prefer thicker oil than modern forks because the orifices are much larger than on a modern fork design.
Top
 Profile
PostPosted: Mon Oct 02, 2017 11:21 am
Offline
Any thoughts on the fork oil viscosity that makes the best of this design?
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Mon Oct 02, 2017 1:06 pm
Offline
Country: WALES
Bikes owned: suzuki gt 550j
http://www.ozebook.com/compendium/suzi/mags/forks.htm
Not an answer for you but worth a read!
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Mon Oct 02, 2017 4:57 pm
Offline
That article provides useful fork spring info.
Have been curious for some time about the mystery “HP-315” oil that the article recommends.
Did some searches for vintage oil cans. Valvoline was big in racing oil back then & they labeled their oil cans with part numbers that were 3 digits.
So I suspect that “HP-315” is Valvoline High Performance oil, part no. 315
Unfortunately the Valvoline part numbers were unrelated to the type & viscosity of the oil.
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Mon Oct 02, 2017 6:44 pm
Offline
I typically end up with 30Wt fork oil in that design of forks.
Top
 Profile
PostPosted: Tue Oct 03, 2017 4:35 am
Offline
Thanks for the response.
Found a topic where Alan H said he uses 20W/50. Also said that’s what Crooks Suzuki used when racing the GT550 back in ’72.
http://www.suzuki2strokes.com/forum/viewtopic.php?f=2&t=12261&p=159522
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Wed Oct 04, 2017 8:24 am
Offline
And that was about all they had back in the day. Today we have expensive Fork oil and trans oil and whole section about that.
BTW the shuttle valve is so called because it shuttles back and forth like a diplomat, but more importantly, like the parts of a shuttle loom. Gives you some idea of where Triumph were getting their engineering ideas... :shock:
Top
 Profile
PostPosted: Fri Oct 06, 2017 3:06 am
Offline
The GT380 build got new oil seals & Bel-Ray 20 weight fork oil. Just used the existing springs & don’t know if they are stock or aftermarket.
The results are pretty good but I don’t think I would recognize if it would have benefited by using 30 weight fork oil.
Am trying to up my game on the GT550 & T500 builds.
The T500 has GT500 forks.
The GT550 & T500 will get aftermarket springs per the Cycle World article.
The GT500 forks have super lame damping rods, so I’m looking into using damping rods for a GS-series bike + emulators.
The emulator instructions include a recommendation for oil weight.
That leaves the GT550 oil weight as a TBD.
How would you describe the performance difference between 20 & 30 weight fork oil?
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Fri Oct 06, 2017 8:18 am
Offline
Thicker oil does increase damping but whether it's enough of a difference is a whole different question. A change to Gold valves and decent damping would be a much more noticeable change on the road and if the GS forks have teflon bushes the difference will be easy to feel.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
Suzuki2Strokes.com
