Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Apr 18, 2019 7:50 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Mon May 16, 2016 7:29 am
Offline
I found stock springs that might work on the early T350 & T500 forks with external springs.
They are longer & provide a good bit more preload.
Post about the springs: http://www.suzuki2strokes.com/forum/viewtopic.php?f=2&t=10874
For forks with internal springs, you just slide the tubes into the triple tree.
But doing this with external springs create the preload.
So does anyone have tips on how to install for fork tubes with external springs & more preload?
(It would seem obvious but I suspect someone has some tips that will make this easier.)
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Tue May 17, 2016 5:07 am
Offline
Bikes owned: T500
Maybe I'm wrong but don't you just put some washers or spacers between top of spring and under lower triple?
Top
 Profile
PostPosted: Tue May 17, 2016 10:25 am
Offline
Maybe my question wasn’t clear.
I was asking for tips on how to most easily assemble the forks.
Using plastic plumbing pipe to add preload for internal fork springs is pretty effective because the springs are long.
But the external fork springs on the T350/T500 are much shorter — using washers can reduce fork travel because the springs can go solid. Max deflection for the T500 springs, which is around 4.7”, is the upper bound limit of preload + fork travel. Also, the springs are badly overstressed at solid height, which is why they go to mush.
_________________
T500 73 project
T250 72
Top
 Profile
Who is online
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
Suzuki2Strokes.com
