Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat May 25, 2019 10:19 pm
Post new topic Reply to topic  [ 2 posts ]
Author Message
PostPosted: Sat Apr 09, 2016 2:47 pm
Offline
Bikes owned: T500
I am nearing completion of my T500 build as seen in the customs section. The front end was rebuilt with all new seals, NOS external springs and I used 15 weight fork oil. I have the bike back together and noticed when I sit on it, the forks compress down quite easily. Its not running yet but if I roll it across the garage and apply front brakes, it will dive pretty significantly. I am just wondering what tips or tricks are available to tighten this up? I figured using the higher weight fork oil would help, but it doesn't seem to have made any difference at all.
Top
 Profile
PostPosted: Mon Apr 11, 2016 2:51 pm
Offline
Country: United Kingdom
Bikes owned: T500_MKIII
Oil would only affect damping if you feel it sags too much under a static load you need to either preload the springs with a spacer or increase the spring rate. Although a stiffer spring might make it ride harsh and given the crude damping no amount of tweaking oil viscosity would give a decent ride.
Try some spacers first.
Ade
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
Suzuki2Strokes.com
