easiest way to check if oil is getting into the chamber
Posted: Tue Apr 30, 2013 9:56 am
by Ramjam
Hi
I'm afraid that two stroke oil is not getting into my middle cyclinder on my gt380. I can't see any blue smoke at all then it is running so I'm afraid that it is 'running' with no lube - although all six lines were just primed by me, after i left the bike for 9 months without running.
Is there are really easy way to check if oil is getting through?
thanks in advance
Ramjam
Re: easiest way to check if oil is getting into the chamber
Posted: Tue Apr 30, 2013 11:01 am
Crack the banjo bolts at the motor and kick it over with throttle wide open - or run it for a minute or so like that. Oil should weep out of any loose bolt. It's crude but worth a try.
A better solution is to remove the oil pump and make a test jig and drive the pump with an electric drill.
My favorite is to remove the pump and prime the lines with an oil of a very different color. Refit the pump and run it. If the lines change back to oil in the tank color, it's all good.
Posted: Tue Apr 30, 2013 5:43 pm
by ConnerVT
tz375 wrote: My favorite is to remove the pump and prime the lines with an oil of a very different color. Refit the pump and run it. If the lines change back to oil in the tank color, it's all good.
+1 for the easiest (and fool proof).
Posted: Sun May 25, 2014 8:20 pm
by rizin
Thanks for this information. I just got a 1973 gt250 going and I am running everything down. Last time I was around oil injection was a little moped.
