hi guys
what do you advise as to 2 stroke ratio for premix for the gt380 just in case my pumps not working and how many oz per 1 gal please would it be i was thinking 50/1 but not sure thats to much oil ??
thanks stu
2 stroke oil ratio
- Country: u.s.a
- Suzuki 2-Strokes: 72 gt380 ,75 gt380
Re: 2 stroke oil ratio
Suzuki Triples are not designed to run pre-mix. Cranks and cases have to be modified, so get that pump working.
- Country: u.s.a
would it be ok just for a test to see if the engine runs
if so how much oil to gas
- Country: United States
- Suzuki 2-Strokes: 1972 Suzuki Gt550
If you premix the oil it will only get in the cylinder. Premix will NOT lubricate your bearings in the crank. Running the motor even for a short time could damage the motor. Just like running a car with no oil in it.
