Page 1 of 2
gt250/gt500 oil pump question
Posted: Wed Aug 22, 2018 11:30 am
by dollydog
are there any designation markings on the 500 pump? i've got a few oil pumps and just wondered if there was a 500 in there. gt250 pump just says iso on it and made in japan so that's not much use. there is 3.9 stamped on top of the bolt that holds the shaft in, but that's it ???
ps, was going to use the 500 pump for the 350
Re: gt250/gt500 oil pump question
Posted: Wed Aug 22, 2018 1:25 pm
The T250/GT250, T350 & T500/GT500 oil pumps have different flow rates.
Posted: Thu Aug 23, 2018 2:01 am
by dollydog
hi jab, i know that bit
but how can you tell the difference without trying them? which was my original question
Posted: Thu Aug 23, 2018 11:01 am
by dorT500
Hey dollydog, under the Google 'Images' tab enter T/GT 500 pump and then T/GT250 pump. From a brief search I made, it appears the pump levers are slightly different. Other than that, yes, my T500 spare oil pumps all have the '3.9' stamped on the reverse thread plunger guide screw. I might add some pics here shortly.
Edit....one pic of a pump (more to come) but even more interesting to me is the vacuum fuel petcock mod...
http://teamghettoracing.com/bikes/road/ ... and-carby/" onclick="window.open(this.href);return false;
Posted: Thu Aug 23, 2018 11:07 am
by dollydog
thanks for that chuck
the levers were the only difference i could see, so according to that a longer lever at a certain throttle position would give more oil? sounds daft though
have you got a t500 pump you could strip down and we'll compare the sizes of the various parts, 250 against 500? i reckon suzuki are trying to pull a fast one
Posted: Thu Aug 23, 2018 1:01 pm
by dorT500
dollydog wrote:........... have you got a t500 pump you could strip down......
Uhh... Yes.
GT250
I've been meaning to strip down at least one of these again anyway to hopefully confirm my thoughts back when, that excess smoking (2T) cannot be exclusively blamed on banjo check valves, wrong adjustment, etc., that is, my thinking a few years ago was that a worn rotating plunger shaft and of course its bore could cause excess oil to bypass around and be discharged with the rest of the metered oil. Pumps out there that in the vast past that have been run dry for some period of time or even worse, have been disconnected from the oil tank and left still bolted on by some that would choose to run pre-mix. Thus increasing the population in the wreckers/salvage yards, though..... ironically.... increasing bike parts availability for us vintage enthusiasts. My theory on this could be wrong....I don't think so...it's just I believe that was my thinking when I last had one apart several years ago. I just need to look inside at the 'works' of one of the pumps again.
Note...it appears to me the reverse thread screw is being shown screwed in the wrong direction but otherwise pretty neat little clip..
https://www.youtube.com/watch?v=1x5Dau9N9cg" onclick="window.open(this.href);return false;"
From what I can remember, each of my spares (at least two previosly used by me) had some kind of issue, save one, that I might not have tested yet.
I can remember many years back on this forum and others that the general consensus was that you should not take one of these pumps apart....that they were not meant to taken apart. Way back when, the idea was to replace them with new ones when they did not meet the discharge rates supplied to the service departments of Suzuki dealerships. I seem to recall that warning is even in one of my service manuals? ............another indication from the manufacturer that just plain wear over the years in these pumps can make them NOT "bullet proof" as many have described over the years?
I'll try and get a chance in the next couple of days to take one apart as you requested.
Posted: Thu Aug 23, 2018 3:01 pm
by dollydog
good man
i've got a definite 250 oil pump already partially stripped down, so i'll get the digital measuring thingy out and start measuring a few bits up. i'm going to peruse your photo's again and see if i can spot any glaring difference
thanks again.
Posted: Thu Aug 23, 2018 5:11 pm
by dorT500
I would not bet $1000.00 that they are exactly alike except for the lever but I would bet......well....I would bet less
that they are the same.
Posted: Fri Aug 24, 2018 6:40 am
by dollydog
one thing i did notice was after taking the triangle off the end, there was a cam inside. i wonder if that's a different size? it's a bit difficult to measure without knocking the holding pin out and taking the [lever] shaft out, but there's a reason for a cam of a certain size, yes? atm, that's my bet. can you get a photo of the pump, end on with the triangle removed? just a visual might give us a clue
Posted: Fri Aug 24, 2018 10:44 am
by dorT500
Posted: Fri Aug 24, 2018 2:12 pm
by dollydog
hmm, thanks for them chuck
most things on mine measure up, but that cam lobe looks far bigger, and unless you've got an exceptionally thin metal rule, then the end aperture is far bigger. i can't get my metal rule in there at all. the 3 holes on the end are 25mm centre to centre, except one which is 27mm ditto and uses 3 x m4 screws. aperture at its widest is 18mm and narrowest 15mm. but that cam definitely looks bigger - way bigger
Posted: Fri Aug 24, 2018 3:26 pm
by dorT500
Posted: Fri Aug 24, 2018 3:52 pm
by dorT500
dollydog wrote:........... the 3 holes on the end are 25mm centre to centre, except one which is 27mm ditto and uses 3 x m4 screws. aperture at its widest is 18mm and narrowest 15mm.
I'll get those for you also.
Posted: Sat Aug 25, 2018 10:16 am
by dorT500
Posted: Sat Aug 25, 2018 1:01 pm
by dorT500
