2 much 2 stroke on 1 side
Everything you want to know about oil but were "afraid to ask"!
chopwhatyagot
Country: usa
Suzuki 2-Strokes: gt750seR
Post by chopwhatyagot »
For some reason, I am pouring 2 strioke oil out 1 pipe alot more then the other 2. I always have to clear it out and that one pipe pours oil. At a stop light it pours oil. How come, only one pipe is overloaded? I am going through a lot of oil, every 8 gallons i need to refill the tank. i have it adjust on the line like reccomended. I appreciate any help.
Re: 2 much 2 stroke on 1 side
Hi,sounds like you have a complete failure of the check valve in the end of the oil line !. I don't know how the plug could possibly still be firing ? I would have thought you'd get hydraulic lock with all that oil/fuel in there :evil: When you say it "pours oil" where from ? The exhaust port, or from the end of the muffler ? Has the pump been apart for any reason ? it is possible to have things around the wrong way ! pump working flat out at idle & hardly any delivery at higher revs :oops:
Regards,
I have an in-progress topic about the oil pump setup on a modified GT750.
viewtopic.php?f=2&t=11662&start=0
That topic is about the possibility of getting the pump 180 degrees out.
Yeadon_m said that getting the oil pump out by 180 degrees will increase oil consumption by a factor of 3.
I think I might have my issue figured out and will post more later this week when I have some time.
Also worth checking: is your bike using transmission oil.
chopwhatyagot
Country: usa
GT750Battleship wrote:Hi,sounds like you have a complete failure of the check valve in the end of the oil line !. I don't know how the plug could possibly still be firing ? I would have thought you'd get hydraulic lock with all that oil/fuel in there :evil: When you say it "pours oil" where from ? The exhaust port, or from the end of the muffler ? Has the pump been apart for any reason ? it is possible to have things around the wrong way ! pump working flat out at idle & hardly any delivery at higher revs :oops:
Regards,
When I say pours oil, I mean smoke. After some research about you post I believe you are correct. I will check the check valve and post my results. Thank you to both you guys for your response and help with this matter!
chopwhatyagot
Country: usa
jabcb wrote:I have an in-progress topic about the oil pump setup on a modified GT750.
That's very good info, Thank you!
chopwhatyagot
Country: usa
My shaft arm was 180 out, Thanks for the information!
:up: What a relieve,glad you found it :lol:
chopwhatyagot
Country: usa
GT750Battleship wrote::up: What a relieve,glad you found it :lol:
Yes sir! It cleaned up and is not pouring smoke at idle anymore. I test drve it and it runs so much better. I am very happy i didnt jet down anymore. Plugs are brown. Its good for now. MUCH better then it was! Thanks for all the help. I will post some problems and solutions for the next guy because this is something i am very intrested in, GT750"s that is!
Yes they are a very interesting machine & keep you interested every time you ride them,mine recently had a badly blocked exhaust,the baffle was clean,but the pipe itself was badly blocked...fitted another pipe & she went like a rocket 8)
