Hey gents read all threads on this but a I'm a little slow just got bike on road runs good
Noticed air in oil lines after my ride is that normal or is there a bad seal in the pump? I bled lines
So there was no air at all in lines tank full. Can't find rebuild kit looked everywhere any ideas?
74 T500 oil pump seals
- Country: United States
- Suzuki 2-Strokes: RD400 T500 Titan GT550
Re: 74 T500 oil pump seals
Forum member bloop2 sells a complete oil pump kit on eBay.
Be extra careful with the oil pump priming bolt because it has left hand threads.
Thank you can't find Bloop2 pump seals on eBay do you have link.
- Country: us
- Suzuki 2-Strokes: GT
The T500 and GT500 have one line that splits to two lines for each cylinder.where these lines split,they can develop air leaks causing air bubbles in oil lines.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
- Country: WALES
Look here viewtopic.php?f=23&t=8422" onclick="window.open(this.href);return false; send him a pm?
98 carb Blackbird and GT550j
Thanks after further inspection think air leak is coming from spilt were lines join together because one line is full the other 3 have air, going try to bond joints not many options out there. Thanks again!
I'm back! So here's were I'm at, made fixture to put a very little amount of air into lines no leaks found that 3 of the 4
check valves were not closing trying to clean them carefully. Open for ideas don't want to take them apart! (check valves)
- Country: WALES
You can clean the lines and check valves with carb cleaner. Allow them to dry.To test them properly you need to fill the lines with 2T oil using a syringe or something similar. Then hang them up with the check valves downwards overnight. The lines should still be full with no bubbles in the morning. If not they are not doing the job and will allow oil to continue flowing into the crankcase after the engine is stopped. Not good! The check valves can be serviced by removing them but unless you know what you are doing its very difficult. New valves can be bought but there are mixed views on whether they work or not and they are expensive. If yours leak i would try to source another set. Good luck
Thanks think I'm all set there hanging right now, looks good so far. hate to take them a part there super clean.
